ST-REALIZER II for ST72264
ldefend1
Posted on June 16, 2003 at 08:42
ldefend1
Posted on June 13, 2003 at 12:18
I intend to use the ST-REALIZER II for ST72264 program development.
Can I use the InDART STX/D to transfer the ST-REALIZER made target hexcode to the target?
Looking forward to your answer....
simonharrison9
Posted on June 16, 2003 at 06:46
In the project folder you will find a .S19 file
Using the inDART, select the programmer and device
Select File > Load > Code Buffer
change the format to Motorola S-record and locate the above file.
Ensure you also configure the option bytes
regards,
Simon
Anglia
ldefend1
Thank you!
