SRAM
elsiun
Posted on October 25, 2003 at 06:04
SRAM
elsiun
Posted on May 17, 2011 at 11:56
Hi every body
How do I access (read & write ) to the 8kb SRAM with the battery backup?
Thanks Kobi
danielh1
Easy, just read and write. Battery backup is for memory retention after the main power has been removed, if you have it correctly activated with PSDSOFT.
elsiun
Thank you all
According to an1560, the xdata is also for the main flash memory and I wont to access the 8Kb SRAM with the battery backup.
Thanks kobi
