SRAM mapping
martinkorn
Posted on September 22, 2006 at 06:28
SRAM mapping
4 REPLIES 4
martinkorn
Posted on May 17, 2011 at 09:32
Is there a possibility to map the internal SRAM to address 0x00000000 ?
So I would be able to use the interrupt vectors without writing to the flash.
sjo
The only way is to put a vector jump table in flash, pointing to ram.
sample attached.
Cheers
sjo
martinkorn
Thanks for your help. I will try the vector jump table.
Cheers
Mako
shangdawei1
i can not found info about it.
only Flash B0/B1 can be mapped to 0x00000000.
how to ?
