2005-12-19 1:04 AM
2005-12-19 12:42 AM
Does anybody have the driver or some examples for ST10F269 or ST10F276 to write and read in a SD-Card with the SPI port. Thank you
2005-12-19 1:04 AM
We haven't such drivers but you can refer to the attached infineon application note. It could be used as a reference for the ST10F269 and the ST10F You can find drivers on infineon web site. I hope this helps, Best regards, Najoua. ________________ Attachments : Ap1603210_Using_SSC.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0Ms&d=%2Fa%2F0X0000000bY4%2Fn20vc9ROSVM69Hj2ePLMY4diVc178n4ggO6JnocjFKE&asPdf=false
