Readout protection one more time
tomas2
Posted on April 01, 2004 at 10:35
tomas2
Posted on March 31, 2004 at 13:26
Hi all,
I have to bother you one more time with questions about the readout protection byte.
Basis:
A blank ST7Flite25 is first time programmed with STVP 1.9.1 in the DIL20 socket , on the ST7MDT10-EPB eval board.
The option byte: readout protection is set ON.
Is it possible to ever reprogramme it, with above tools ?
1. When using the internal RC oscillator in the final application ?
2. When using an external crystal in the final application ?
If so - how ( step by step please )?
Any other tools making this possible ?
Tomas
jatin
Posted on April 01, 2004 at 08:18
Yes, you can reprogramme the read out protection option bytes.
Procedure is :
1. First using STP7, first program the option bytes with Read out protection setting - OFF.
2. Step1 will also erase your program memory(the STP7 1.9.1 does n't erase the internal RC calibration values). Reprogram your program your memory.
3. Now, you can reprogram the desired/new option bytes.
[ This message was edited by: Jatin on 01-04-2004 11:49 ]
tomas2
Hi Jatin,
fast and accurate as always !
By misstake earlier I tried to set the option byte OFF, but I used ''program all tabs'' instead of ''program current tab''.
That's the way is goes for an OTP-oldie coming from ST62....
Many thanks !
Best regards,
Tomas
