Problem with memory access via JTAG interface
cm1
Posted on April 18, 2008 at 00:34
cm1
Posted on May 17, 2011 at 11:32
I want to program flash memory on STR910FAM32. I have a question after read the reference manual.
There are 3 TAPs on JTAG bus. While the one working, the other 2 in BYPASS. But how can I control which TAP are in BYPASS? I want to access flash memory, what the next after supply power on chip?
