Pb ST10Flasher
jm23
Posted on May 04, 2004 at 14:30
Pb ST10Flasher
4 REPLIES 4
jm23
Posted on April 30, 2004 at 12:30
I have a pb with ST10Flasher. I want to download a program into an external flash (AM29F400) with the ST10 Flasher. What are the directives to do that.
Thanks and best Regards for your answer.
najoua
Posted on April 30, 2004 at 12:59
It is not possible to use ST10Flasher for programming the AM29F
(You will find in attachment a document dealing with how to use the ST10Flasher in general)
________________
Attachments :
ST10Flasher_Usermanual.doc : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0OZ&d=%2Fa%2F0X0000000bYQ%2FCQiRfkpTytfeIBw48PXho6zIu9M4GPOFgBDTKChNDWY&asPdf=false
jm23
Posted on May 03, 2004 at 08:47
Thank you for your answer but if you want you can read the doc attached in this post and you can see that it's possible to program an external flash with st10fasher
jm23
Posted on May 03, 2004 at 09:47
Please, can you read the doc attached to this post
Regards.
________________
Attachments :
ST10FlasherDLL.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I005&d=%2Fa%2F0X0000000bYP%2FCk0L3j7cNMbqgGDK8nkFLHuti_C9rGte5SJ.qW_y6rk&asPdf=false
