need technical information about ST7538P
hakan
Posted on May 11, 2005 at 11:27
hakan
Posted on April 19, 2005 at 12:33
I need the technical support about ST7538P and evaluation board.
1) What is the allowed maximum node count in one network ? What is the number of slave nodes in network where there is one master modem ?
2) Is there any error correction algorithm in ST7538P ? If not how can they imlement error correction in their system.
3) In ST7538 FSK POWER-LINE TRANSCEIVER DEMO-KIT with ST72C334 can user make development on program with ST72C334 ? Is it possible for user to change the parameters of ST7538P ? Can we provide the source code to user ?
4) In Demo Kit is it possible to change the amplitude and power of transmitted signal to power line ?
5) We also need the user guide and Demo Kit . Can you please send it to us.
Best Regards;
hakan
Thanks Emile ;
We are also the distributor of ST .To compare with the other competitor PLM's customer want to know the maximum node count in one system .( Is it can be 500 node in a system).
Could you also gave a link for user guide for ST7538 demo board.
best regards,
