2025-06-30 1:33 AM - last edited on 2025-06-30 2:16 AM by Peter BENSCH
We are using ST33HTPH2X32AHE1 and SGM804-2.93YN5G chips for our application. Can you please share MSL (Moisture Sensitivity Levels) for this IC?
Thanks,
Sonali
2025-06-30 2:15 AM - edited 2025-06-30 2:16 AM
The SGM804-2.93YN5G is not from STMicroelectronics, but from SG Micro Corp.
You can always find the value for MSL in the Material Declaration, which can be found in the tab Quality & Reliability, in your case here.
Hope that helps?
/Peter
Hope that helps?
/Peter
2025-06-30 3:05 AM
Thanks, Peter.
