MIDI and ST7
ulivo15
Posted on August 13, 2004 at 08:49
MIDI and ST7
4 REPLIES 4
ulivo15
Posted on July 28, 2004 at 10:51
Hi to everybody,
i'd like to make a sipmle MIDI piano that should be connected to my computer. Which ST7 have implemented the MIDI serial protocol?
I thank you
jatin
Posted on August 10, 2004 at 06:48
ST7 do not have any protocol by the name MIDI serial protocol. But have I2C, SPI etc. Could you explore more about the MIDI serial protocol?
parveen
Posted on August 12, 2004 at 08:07
You can use ST7 micros with SCI - Serial communication Interface (e.g. devices like ST72F264 or ST72F521). The SCI can be interfaced to create MIDI interface and I/Os can be programmed as your Piano keys.
Hope this helps,
ParveenG
ulivo15
Hi ParveenG,
I have tried with the SPI protocol with a st7lite09, as you can find in my other question, but after a byte trasmission i have 5 volt fixed at pin 3 of the port B (used for the SPI trasmission in master mode). I should have 0 volt. I have tried in several ways, but i couldn't find the way to reset the pin 3 of the port B. Something is wrong? Have you a solution?
I thank you
