2005-12-20 2:22 AM
Help with USB under uClinux on STR71x
2005-12-20 2:22 AM
Hi ARM experts,
may I invite you to the USB forum and ask if you can try to help Dan with his problem? You can follow the link bellow... Thanks & Regards aNt http://mcu.st.com/mcu/modules.php?mop=modload&name=Splatt_Forums&file=viewtopic&topic=3053&forum=12Quote:
On 29-11-2005 at 12:18, dan2003 wrote: Hi, I'm looking for something along these lines. I followed the instructions in AN2119 and successfully built the uClinux for the STR71x but was dissapointed to find there is no USB drivers. So i downloaded the latest uCLinux hoping thepatch had been merged into the 2.6 kernel and that USB drivers were available, but again no such luck. Please let me know of any USB patch for kernel 2.4 or even better an up-to-date patch against the latest uClinux including kernel 2.6 support with USB. Thanks Dan
