Help - Floating library or 32bit calculations for ST72324
shlomo2
Posted on March 25, 2004 at 14:40
5 REPLIES 5
shlomo2
Posted on March 25, 2004 at 11:08
Does someone have a floating point library or 32bit calculation library for the ST72324.
Do you know of any other way to solve equations of large numbers (16bit x 16bit)
shlomo2
Posted on March 25, 2004 at 14:21
Thanks for your reply, I will try to use it.
Have you ever used the library files form Metroworks calles float.h?
They say it is for ST7 I have included the file but results are zero on floating numbers...
shlomo2
Posted on March 25, 2004 at 14:22
shlomo2
Problem solved beutifully.
Metroworks holds a library called float.h
all floating numbers has to be writen as x.0 for real or x.x for fraction.
Cannot attach files in here (?? don't know why) whoever needs it just email me.
