Hello, i have designed a NFC antenna in the eDesignSuite NFC Inductance, and downloaded the .prj file. What can I do with it. Can I import it, in a software to generate a Gerber ? I would like to design it on a flexible PCB. Best regards Jesper
JNiel.3
Patrizia BELLITTO
Hi @Community member​ ,
the .prj file you can export from eDesignSuite can be used only inside the tool itself, to recover the specifications you inserted and reopen the project, in your case with NFC Inductance tool. You can't import anywhere else except from our dashboard on https://eds.st.com/console/#/dashboard
Patrizia
JNiel.3
Okay, perfekt. Thank you for your time :)
Have a great day!
