Frequency upgread to 16MHz
seecure
Posted on August 31, 2004 at 06:40
seecure
Posted on August 19, 2004 at 19:15
ST72F521/Cosmic/indart
I've developed my project with Fosc=8MHz. I'd like to increase the Focs to 16MHz,by External RC crystal. when I used the datablaze programer with ''Oscillator option type-resonator Oscillator'' in the option byte it works properly.
The quetion is: How can I fix the 16MHz Fosc to work with the debugger?
I'd like to use the external crystal on my target as the Fosc in debug mode, is it possible ?
atz
shreya
I think the section on ''Configuring the MCU'' in the ''inDart-STX for ST7'' manual should help you.
