Failed to load FLASH loader
peternovak669
Posted on March 20, 2011 at 16:20
Hi, I have problem with IAR and Downloading files to FLASH memory. Yesterday was everything allright but today when I wanted download my code to FLASH, it was impossible and still is...
This is in my debug log:
Sun Mar 20 15:57:50 2011: Loaded macro file: C:\Program Files\IAR Systems\Embedded Workbench 5.4\arm\config\flashloader\ATMEL\resources\
FlashAT91SAM7Sxx.mac
Sun Mar 20 15:57:50 2011: Sign on message from :
Remote Debugging Interface for JTAG in-circuit debugging
Sun Mar 20 15:57:50 2011:  ---------------------------------------- FLASH Download V1.3
Sun Mar 20 15:57:50 2011:  ---------------------------------------- 14/November/2005
Sun Mar 20 15:57:50 2011:  ---------------------------------------- PLL Enable
Sun Mar 20 15:57:50 2011: -------------------------------Set CPSR  ----------------------------------
Sun Mar 20 15:57:50 2011: CPSR     000000D3
Sun Mar 20 15:57:50 2011: ------------------------------- The Remap is NOT -----------------------------------------
Sun Mar 20 15:57:50 2011:  ---------------------------------------- Chip ID   0xFFFFFFFF
Sun Mar 20 15:57:50 2011:  ---------------------------------------- Extention 0xFFFFFFFF
Sun Mar 20 15:57:50 2011:  ---------------------------------------- Flash Version 0xFFFFFFFF
Sun Mar 20 15:57:50 2011: -------------------------------Set PC ----------------------------------------
Sun Mar 20 15:57:51 2011: 6656 bytes downloaded and verified (6.94 Kbytes/sec)
Sun Mar 20 15:57:51 2011: Warning: Target inconsistency detected in Memory range 0x00000000-0x000019FF
Sun Mar 20 15:58:05 2011: Fatal error: There were warnings during download of FLASH loader, see Log Window   Session aborted!
Sun Mar 20 15:58:05 2011: Failed to load flash loader: C:\Program Files\IAR Systems\Embedded Workbench 5.4\arm\config\flashloader\ATMEL\
AT91SAM7S64-EK\internalflash-sam7s64.out
Sun Mar 20 15:58:05 2011: Failed to load flash loader: C:\Program Files\IAR Systems\Embedded Workbench 5.4\arm\config\flashloader\Atmel\
AT91SAM7S64-EK\flash-at91sam7s64.flash
Pls, what can I do ?
Thanks for helps.
P.
Posted on March 28, 2011 at 20:03
Yeah, well using a ATMEL flash template is a sure fire way to fail on an STMicro part. Make sure you're picking the right target CPU, and have the right flash memory setup.
