mueller2
EMU3 target connector for QFP32
  • December 2, 2003
  • 4 replies
  • 920 views
Posted on December 02, 2003 at 03:21
mueller2
mueller2Author
Posted on November 27, 2003 at 08:04
Hi
Is there anybody who can tell me where to obtain additional target connectors for the EMU3 emulator using QFP32 footprint.
I need ti for the ST72F324K2T6
It's the small square (8 by 8 mm) PCB, which is soldered to the target board, to connect the emulator to the target.
I would appreciate very much to have a make and part numer.
Regards from rainy Denmark
Kurt Müller
Danfoss A/S
shreya
Visitor II
November 28, 2003
Posted on November 28, 2003 at 08:28
Hi!
If you mean the socket and cover kit then you should contact Yamaichi I think(check in the probe user manual to see which manufacturer's parts have been used). In case you mean extra flex cables, the ST distributor should be able to help.
Regards from tropical India,
Dasg
alain2399
Visitor II
December 1, 2003
Posted on December 01, 2003 at 11:43
It is possible to order all the tools spare parts directly from ST.
Check the spare part list in order to find the order code corresponding to the items you are looking for in this web site at:
http://www.stmcu.com/modules.php?name=mcu&file=accessory&FAM=15
mueller2
mueller2Author
Thank You to both of you
I found the sparepart on ST site
It has ST order number AS-TQFP32.
Actually i think it is an IRONWOOD ELECTRONICS, INC. device.
www.ironwoodelectronics.com
Their part number SF-QFE0325A-L-01.
Nice day to all of you
Kurt Müller
