emergency_
irmakci2
Posted on March 15, 2006 at 10:13
emergency_
4 REPLIES 4
irmakci2
Posted on March 15, 2006 at 09:16
Hi
In fact we have some problems with cosmic c compilers
void x(void)
humi_val=humi_val*143 //doesn't give me right results
//humi_val is global unsigned int
luter
Posted on March 15, 2006 at 09:31
it is just a common optimization. if u do not use this variable anymore compiler omits it.
ok, if u want your code to be compiled as it is, use ''volatile'' definition for such variable. it is just to show u what u want to see, but ussually ''volatile'' is used for several cases only. do not take it as rule for all cases.
i work with cosmis since 1 year and did not find any compiler errors.
irmakci2
Posted on March 15, 2006 at 10:01
thank you for your care
irmakci2
Hi.But what means optimizition exactly?how can I solve this problem from cosmic menus?and I know only this means volatile is used for hardware registers because registers is changed externally if I know correctly:).And as you said compiler doesnt optimize volatile variables but I dont know how ı can solve from menu:
If you help me I'd be happier
Thank you
