cycle counter in st7 simulator / ice
rob239955_st
Posted on November 06, 2003 at 05:44
rob239955_st
Posted on November 05, 2003 at 17:58
Hi
i've been using the st7 for about 1.5 years nowm, but one thing i notice is that you can't count cpu cycles. - by that i mean count the cpu cycles as you single step or animate thoruough code (like you can in the mplab dev kit)
Does any one know if the st simulator / emulator can do this (i'm using the dvp)
any help would be appreciated.
regards
rob carter
shreya
Posted on November 06, 2003 at 05:09
The trace records data for each cpu cycle. Does that help? If no, could you tell me which device you are using?
rgds..
sjo
Rob,
This can be done in the simulator, look under ST7 Registers,Time.
sjo
