Can STR9 support 8 UARTs?
vpap
Posted on February 14, 2007 at 17:31
vpap
Posted on May 17, 2011 at 09:36
I intent to use the STR9 cpu with 8 exar UART chips(XR19L210), each with its own interrupt line and 16 byteTX/RX FIFO.
Do you think the STR9 would be capable to respond to this kind of interrupt load while using the ethernet MII?
The anticipated baud rate for the UARTS are less than 38400.
Thank you.
Viron.
