2017-02-08 10:01 PM
Hello All,
I am new to SPC environment. I am trying to do the configurations for the power management. I am using SPC5studio version 5.2.1, I am not finding the settings to configure the modes (e.g RUN Mode 0, HALT mode, STOP mode, etc) in the application wizard so that I couldn't able to auto generate the code using code generator.
I am working on SPC560B54L5 evaluation board, kindly suggest the steps to generate the code for power management using code generator.If any ready to use code please update.
Thanks in Advance..
Best Regards,
R.SanthamurthySolved! Go to Solution.
2017-02-09 08:53 AM
Hello
R.Santhamurthy ,
You can not configure R
UN Mode 0, HALT mode, STOP mode, STANDBY mode by the configurator.
Anyway , you can use some application example as example.
SPC560Dxx OS-Less WKPU LPM Test Application for Discovery
SPC560Dxx_RLA WKPU API Test Application for Discovery
you should respect the figure 72 of RM0037
Best regards
Erwan
2017-02-09 08:53 AM
Hello
R.Santhamurthy ,
Best regards
Erwan
