LPS25HB abnormal temperature reading
Options
2018-09-29 12:34 AM
Hello;
I now test the LPS25HB pressure sensor with abnormal temperature reading. The actual ambient temperature is 30 degrees, but the read-out data TEMP_OUT_H (2CH) = DAH, TEMP_OUT_L = 50H. Slowly changing the ambient temperature, temperature reading also changes, indicating that the temperature sensor is working properly. But according to the register reading instructions, the reading value is negative, so I want to know about the temperature register numerical interpretation.
thank you very much.
0 REPLIES 0
