what is the sensitivity and accuracy of LIS2DW12 accelerometer and its on chip temperature sensor?
AVenk.2
DSull.3
Hi, you can find these data in the datasheet, p. 6.
The accuracy is 1 LSB sensitivity, but you have to consider the Zero g level, and compensate it.
The temperature sensor data are in p. 8.
https://www.st.com/resource/en/datasheet/lis2dw12.pdf
\DK
DSull.3
\DK
