The output data from the sensor in STWIN can be displayed directly on the PC in real time?
‎2021-07-15 1:24 AM
‎2021-07-15 1:24 AM
Yes, it can but you will need to develop a dedicated FW with AlgoBuilder and read the data with Unicleo. AlgoBuilder is a graphical tool that can help you to develop, in few easy steps, a dedicated firmware that can interact with Unicleo, which is the software that will give you possibility to check the sensor data in real-time.
‎2021-07-15 1:24 AM
