2025-02-20 11:58 PM
2025-02-21 8:59 AM
Always look at the datasheet.
In your case: paragraph 2.3 table 5 clearly states +/-15deg offset. Which means you need to do 1-point calibration to get the correct absolute value: offset to be subtracted = temperature from the sensor - actual temperature.
Other parts have smaller offsets thanks to factory calibration.
2025-02-21 8:59 AM
2025-02-25 9:36 PM
Thank you, Andrea
Are there any other datasheets available for the LIS2DW12 temperature sensor?
2025-02-26 8:56 AM
the datasheet for LIS2DW12 is already online and there is no other datasheet
if you need an accurate environmental temperature sensor, check STTS75
2025-04-30 12:44 AM
Thank you, Andrea
Problem solved
