2024-06-12 12:50 AM - last edited on 2024-07-10 5:55 AM by Peter BENSCH
we would like to use the LPS22HHTR barometer sensor in a new product. Now it is not clear from the datasheet how the sensor should be placed in the housing. I have not found a design guide for this product. Are there certain requirements regarding the distance between sensor and housing wall, minimum volume between sensor and housing wall, requirements for the opening used in the housing (e.g. for membranes used, etc.)?
Thank you for your prompt feedback.
Best regards,
Pascal
2024-07-10 5:59 AM
Welcome @pasnet, to the community!
Unfortunately, you posted your question in the wrong forum, so it could only be found by chance.
Have you looked at AN5227 and TN0018, where your questions should actually be answered?
/Peter
