i am using steval-mki109v3 & mki172v1 & Unico GUI how can i feed angle & heading data to control other peripheral
kgor.1
Federica Bossi
Hi @kgor.1​ ,
Welcome to ST Community!
STEVAL-MKI109V3 is a motherboard for ST MEMS adapters.
The Unico-GUI can be used to show data coming from the adapter board (e.g. STEVAL-MKI172V1) when the motherboard has been programmed with a dedicated firmware.
For the case STEVAL-MKI109V3 + STEVAL-MKI172V1, angle and heading data computation is done at software level in the Unico-GUI.
To control other different peripherals, you may need a dedicated firmware or hardware.
