How do you convert IIS3DWB accelerometer data to vibration values? Is there an algorithm that has to be part of the c code?
MT.6
Is IIS3DWB data already vibration information, or is there some algorithm needed to convert to vibration data? https://www.st.com/en/mems-and-sensors/iis3dwb.html
Vibrometers and accelerometers both measure acceleration. No conversion is necessary.
5 REPLIES 5
MT.6
Thanks TDK. How do people chart out frequency vs g? Trying to see how to get the frequency component. I have heard of people doing FFT, but, not sure how that works.
FFT can be used to show frequency information. There is a wealth of information available if you search for it.
https://blog.endaq.com/vibration-analysis-fft-psd-and-spectrogram
MT.6
Thanks TDK, as you can see there is some conversion work that has to be done on accelerometer data to get vibration information .... I will look into c implementation
Suppose that depends what you mean by vibration information. Clearly, if you want the FFT, you need to perform the FFT.
