Hi, I am using sensor tile box in pro mode. I just flashed the open source code "BLE Sensor" on board and tried to display in ST BLE Sensor mobile application. It is not showing any output. Is it mean pro mode will not work in mobile application?
AN J.1
Please reply
Eleon BORLINI
Hi @AN J.1​ ,
did you try with the recover procedure described in this post? I attach here also the last version (v 3.4.7) of the default firmware (with Bootloader).
If my reply answered your question, please click on Select as Best at the bottom of this post. This will help other users with the same issue to find the answer faster.
-Eleon
Eleon BORLINI
Hi @AN J.1​ ,
-Eleon
