Generate .h file from .ucf Unico file ( LSM6DSOX )
SHadj.1
I'm working with the LSM6DSOX Machine Learning Core.
I found the way to go from the data logs to the .ucf file, but I was wondering if there was an already available way to generate the corresponding .h file directly from Unico.
I guess it would be relatively easy to code something to do it automatically, but it would be way less hassle if it already exists.
SHadj.1
Nevermind, I just found out how.
In the "Options" tab there is a "C code generation" button at the bottom right corner.
Hope this will help someone else.
SHadj.1
