Download software on the board without debugging
Nickname14333_O
Posted on July 28, 2011 at 12:35
After downloading my software on the board, it only can executes when I am in debugging mode and make a RUN.
When I restart the board without debug, my software isn't effective anymore, whereas it's supposed to still be loaded on the board.
Do you have an explanation ? What can I do to really have an embedded application ?
Best Regards
Helene
mili
Posted on July 29, 2011 at 12:18
If u have really flashed the code to the board, it should execute whenever u press the reset button on the board. try to remove all breakpoints , download to board flash memory and check again.It should work.
-rose
Nickname14333_O
Posted on August 01, 2011 at 14:51
I resolved my problem. I only had to reflash the iNEMO_DFU Project on the board.
Thank you for your answers.
Hélène
