2024-06-20 3:10 AM - last edited on 2024-06-20 3:30 AM by Peter BENSCH
Hello experts,
I am using rock chip board with android 12 on it along with the sensor lsm6dsox connected on i2c2.
I have added the driver and compile the Linux and then build android images.
After booting I can see device is detected on i2c and probed successfully, now when I tried to get the same sensors list at android level I get 0 sensor device listed.
below are the probe logs
rk3568_s:/ # logcat | grep lsm
01-01 12:00:00.830 0 0 I st_lsm6dsox_i2c 2-006b: Linked as a consumer to regulator.17
01-01 12:00:00.831 0 0 I st_lsm6dsox_i2c 2-006b: Freq Fine -262 (ts 25262)
01-01 12:00:03.552 0 0 I st_lsm6dsox_i2c 2-006b: MLC loaded (1) MLC 1 FSM 00
01-01 12:00:03.556 0 0 I st_lsm6dsox_i2c 2-006b: Device probed
After checking online I get below link from support team
https://github.com/STMicroelectronics/st-mems-android-linux-sensors-hal
I followed the same link with multi-hal configuration as well as with HIDL configuration but no sensor is listed in dumsys sensorservice
rk3568_s:/ # dumpsys sensorservice
No Sensors on the device
devInitCheck : 0
Can you please help me to setup the HAL layer in my andoird 12.
you help is much appreciated, thank you in advance......
2024-06-24 10:53 PM
hi All,
can anyone checked this issue ....?
