wifi_opr_rate_mask
Grigori
Posted on February 22, 2017 at 11:29
We use SPWF01SC module in customer product. Device will be used in complex WiFi environment.
We tried to test WLAN connectivity in 802.11b, g and n setups in order to determine which one will better serve our needs in real world conditions.
We were trying to limit connectivity to 802.11g only by disabling 802.11b,n using wifi_opr_rate_mask parameter.
It seems this limitation works properly in other combinations, but mask 0x3FC0, 11 1111 1100 0000b (802.11g only) does not work for us.
Discovery simply does not find any networks, when we apply this operating rate mask.
Base station (router) seems to work properly with other devices in 802.11g network.
wifi_ht_mode set to 1.
Is there any bug or a misunderstanding on our side?
#ieee-802.11 #wi-fi
Gerardo GALLUCCI
Posted on February 22, 2017 at 19:16
b-modes are mandatory for association. Disabling them, association request is discarded from AP. You should get a WIND containing a reason code.
Posted on February 23, 2017 at 10:01
Thank you very much for explanaton.
