We have encountered difference in height dimension on ST1S10PHR. Per datasheet, height under "A" should be between 1.5mm - 1.7mm, but we have received parts at 1.47mm. Is this normal? is there a tolerance height range of +/-0.05mm to consider? Thanks!
ENeoh.1
0 REPLIES 0
