SPWF01SA11 ERROR: SSL/TLS Error: Unable to connect (-308)
Viktor Duma
Posted on October 11, 2017 at 20:52
Hello! I have an issue with SPWF01SA11 one-way SSL/TLS connection. I am sure I check all similar cases here, but still can't solve my problem. I tried certificates from tutorial en.STSW-TLSpack example_2,
tried to generate my own certificates and got
ERROR: Unable to load CA certificate.
 And now I am trying www.geotrust.com/resources/root-certificates/#.
Through teraterm send commands:
AT+S.TLSCERT2=clean,all
OK
AT+S.SETTIME=1507665904
OK
AT+S.TLSDOMAIN=f_domain,GeoTrust Global CA
OK
AT+S.TLSCERT=f_ca,1216
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
OK
AT+S.TLSCERT=f_content,0
# TLS loaded CERTs:
# CA Cert: YES
# Client Cert: NO
# Client Key: NO
# Domain Name: YES - GeoTrust Global CA
AT+S.SOCKON=ssltest11.bbtest.net,443,s,ind
What is wrong? Please help me! I waste about week for that (((
19 REPLIES 19
Posted on October 13, 2017 at 07:44
Hello Viktor,
Error -150 means 'ASN date error, current date before'. So probably you forgot to set the current date correctly or, since you've generated new certificates, you used the old configuration and setup the date as the date of your first tests...
Viktor Duma
Posted on October 13, 2017 at 15:20
    Thank you for your time and patience for me! Now it works. It was really difficult to save certificate properly trough the tera term. My colleague wrote the script in C#, and now I can do that with no problem. And one more question. Please suggest me the certificate for access to google.com, for example.  Now I succesful download Entrust Root Certification Authority to the device but can connect only with
http://www.ssllabs.com
. Other sites device cant access and rise ERROR: SSL/TLS Error: Unable to connect (-188).
Posted on October 13, 2017 at 15:33
You're welcome!
If you want to access to another site, for example google.com, you'll need to download the Certification Authority certificate for that site (
https://www.thesslstore.com/blog/how-to-view-ssl-certificate-details-in-chrome-56/
Please note that, since the module has small flash size, it is able to handle just one CA at a time. If you want to connect to several servers you have to cleanup each time the Flash and load new certificate.
Viktor Duma
Posted on October 17, 2017 at 14:51
I am sorry, still, cant connect to google. I got the certificate from
https://pki.google.com/
 . Also downloaded from the browser.  Tried a lot of different certificates like Geo trust. But I can connect to
 with
Entrust Root Certificate Authority�?G2.
Guys, what is wrong?
OK
AT+S.SETTIME=1508244012
OK
AT+S.TLSDOMAIN=f_domain,google.com
OK
AT+S.TLSCERT=f_ca,1501
MIIEKDCCAxCgAwIBAgIQAQAhJYiw+lmnd+8Fe2Yn3zANBgkqhkiG9w0BAQsFADBC
MQswCQYDVQQGEwJVUzEWMBQGA1UEChMNR2VvVHJ1c3QgSW5jLjEbMBkGA1UEAxMS
R2VvVHJ1c3QgR2xvYmFsIENBMB4XDTE3MDUyMjExMzIzN1oXDTE4MTIzMTIzNTk1
OVowSTELMAkGA1UEBhMCVVMxEzARBgNVBAoTCkdvb2dsZSBJbmMxJTAjBgNVBAMT
HEdvb2dsZSBJbnRlcm5ldCBBdXRob3JpdHkgRzIwggEiMA0GCSqGSIb3DQEBAQUA
A4IBDwAwggEKAoIBAQCcKgR3XNhQkToGo4Lg2FBIvIk/8RlwGohGfuCPxfGJziHu
Wv5hDbcyRImgdAtTT1WkzoJile7rWV/G4QWAEsRelD+8W0g49FP3JOb7kekVxM/0
Uw30SvyfVN59vqBrb4fA0FAfKDADQNoIc1Fsf/86PKc3Bo69SxEE630k3ub5/DFx
+5TVYPMuSq9C0svqxGoassxT3RVLix/IGWEfzZ2oPmMrhDVpZYTIGcVGIvhTlb7j
gEoQxirsupcgEcc5mRAEoPBhepUljE5SdeK27QjKFPzOImqzTs9GA5eXA37Asd57
r0Uzz7o+cbfe9CUlwg01iZ2d+w4ReYkeN8WvjnJpAgMBAAGjggERMIIBDTAfBgNV
HSMEGDAWgBTAephojYn7qwVkDBF9qn1luMrMTjAdBgNVHQ4EFgQUSt0GFhu89mi1
dvWBtrtiGrpagS8wDgYDVR0PAQH/BAQDAgEGMC4GCCsGAQUFBwEBBCIwIDAeBggr
BgEFBQcwAYYSaHR0cDovL2cuc3ltY2QuY29tMBIGA1UdEwEB/wQIMAYBAf8CAQAw
NQYDVR0fBC4wLDAqoCigJoYkaHR0cDovL2cuc3ltY2IuY29tL2NybHMvZ3RnbG9i
YWwuY3JsMCEGA1UdIAQaMBgwDAYKKwYBBAHWeQIFATAIBgZngQwBAgIwHQYDVR0l
BBYwFAYIKwYBBQUHAwEGCCsGAQUFBwMCMA0GCSqGSIb3DQEBCwUAA4IBAQDKSeWs
12Rkd1u+cfrP9B4jx5ppY1Rf60zWGSgjZGaOHMeHgGRfBIsmr5jfCnC8vBk97nsz
qX+99AXUcLsFJnnqmseYuQcZZTTMPOk/xQH6bwx+23pwXEz+LQDwyr4tjrSogPsB
E4jLnD/lu3fKOmc2887VJwJyQ6C9bgLxRwVxPgFZ6RGeGvOED4Cmong1L7bHon8X
fOGLVq7uZ4hRJzBgpWJSwzfVO+qFKgE4h6LPcK2kesnE58rF2rwjMvL+GMJ74N87
L9TQEOaWTPtEtyFkDbkAlDASJodYmDkFOA/MgkgMCkdm7r+0X8T/cKjhf4t5K7hl
MqO5tzHpCvX2HzLc
OK
# TLS loaded CERTs:
# CA Cert: YES
# Client Cert: NO
# Client Key: NO
# Domain Name: YES - google.com
OK
AT+S.SOCKON=www.google.com,443,s,ind
ERROR: SSL/TLS Error: Unable to connect (-322)
Viktor Duma
Posted on October 17, 2017 at 15:48
I did it before.  -188 ASN sig error, no CA signer to verify certificate
Any ideas?
# CA Cert: YES
# Client Cert: NO
# Client Key: NO
# Domain Name: YES - www.google.com
O
Receive: K
Sent: AT+S.SOCKON=www.google.com,443,s,ind
Receive:
Receive: connect (-188)
Viktor Duma
Posted on October 17, 2017 at 16:26
I read that. What can you advise me when I need do that? Use mutual connection? Thank you!
Posted on October 17, 2017 at 15:36
Hi Viktor,
the error -322 means that the domain name is wrong. Try to use as domain name
http://www.google.com
Cheers
Posted on October 17, 2017 at 16:16
This happens because the certificate you have loaded is too big for the module's RAM availability...the module isn't able to handle certificates greater than 1.3 KBs when dealing with one-way authentication and, when using muthual authentication, the overall size of the certificates and private key should be less than 3KBs.
Please refer to
http://www.st.com/content/ccc/resource/technical/document/application_note/f2/8e/ae/8f/fe/77/44/aa/DM00176553.pdf/files/DM00176553.pdf/jcr:content/translations/en.DM00176553.pdf
  for more informations...
Posted on October 17, 2017 at 17:13
In this case there is no solution unfortunately...the mutual authentication is used only when the server requests it (and https doesn't use any mutual authentication).
But consider that, usually, in a IoT scenario, clouds platforms (AWS, Azure etc.) use smaller certificates with respect to the ones used for https (the latter case is for desktop, while IoT clouds are intended for very constrained devices).
One advice to you is to use, in case of mutual authentication, private keys and certificates ECDSA-signed that, at the same level of security of RSA-signed certificates, are smaller. For example with Amazon AWS it is possible to use them.
Viktor Duma
Posted on October 18, 2017 at 14:58
I understand. Thank you for support! Yesterday I download the certificate for Amazon, according to tutorial AN4963
50/61 ,
and it works. But when I do the same for other sites - doesn't work. Certificates about 1200 kb. What the secret? )))
