Problem with memory together with micropython and WPA2 enterprise we use the spwf04sa
Johan Holstein
Posted on April 20, 2018 at 18:03
Dear people at ST,
It seems that spwf04sa have not enough memory for micro python together with WPA2 enterprise.
Is that correct or did we make a mistake?
Best regards,
Johan Holstein
Elio Cometti
Senior II
Posted on April 23, 2018 at 07:48
Dear Johan,
WPA2 enterprise is known to require a lot of memory.
In my experience, setting ramdisk_memsize=2 and python_memsize=22 should allow to connect to a WPA2 enterprise networks.
If these settings are not enough in your case, please try disabling the ram disk (ramdisk_memsize=0) and/ or further reduce python_memsize.
