Perform HTTP delete, put
pontus2
Posted on July 13, 2016 at 14:56
Is it possible to perform a HTTP DELETE or HTTP PUT through the AT commands (without opening socket etc.). Is it possible using the custom request command  AT+S.HTTPREQ? I have found no example of how to use  AT+S.HTTPREQ.
Pontus
#http-request-delete-put-at
Gerardo GALLUCCI
Posted on July 18, 2016 at 11:31
there are several howto on this forum about httpreq command. I think it's possible to perform every request you need using that command.
regards
j
