List of parts BLUENRG-1 balun
paolovasta9
Hello everybody,
I designed a board with Bluenrg-1 and discrete balun with the topography draw in the Datasheet.. the problem is that there isn’t a BOM with the value of passives of the balun... where Can I found it? I used the values of the balun of Bluenrg-MS but the sensitivity of device is very very bad (work only at 5cm from the peripheral) but the RSSI measured is right!!!
Thank you all
0 REPLIES 0
