Is BLUENRG-M2 module need firmware upgrade?
Skada.3
Hi
I am using bluenrg M2 module, bluenrg_m2sa and it's expansion board x_nucleo_bnrg2a1.
Module with expansion board is working but module purchased separately is not. As mentioned in the errata sheet of expansion board do I need to update every new module?Errata sheet link is as follows
https://www.st.com/resource/en/errata_sheet/dm00691490-board-limitations-stmicroelectronics.pdf
BLin.3
Hi @Skada.3​, were you able to get this resolved?
Skada.3
Hi BLin.3
Not exactly still have to update the new module with firmware mentioned in the errata sheet.
