I am trying to integrate stsafe-A110 in a project based on ESP32. I cannot have i2c working (e.g. StSafeA_Echo() is failing ...) .
Thierry Didi
Would it be possible to have a description of i2c read / i2c write commands (start condition, ack, end condition ... ). I cannot find this description in STSAFE datasheet.
best regards,
Thierry
Thierry Didi
Hello, here is one precision about what "not working" means:
  • I2C Read and I2C write functions seem to be working (i.e. they return OK, while if I change the I2C address for instance, they fail)
  • But the device always replies with a first byte equal to 0X01, and next bytes equal to 0XFF, 0XFF ....
Do you have any idea about where this could come from ?
Best regards
Thierry
Benjamin BARATTE
Hi Thierry,
Could you share a capture of the I2C communication between your ESP32 and the STSAFE-A110 ?
Error 0x01 reported by STSAFE-A110 is general communication error, generally link to wrong CRC at the end of the command.
Thanks,
Best Regards,
Benjamin BARATTE
Thierry Didi
Hello Benjamin,
Thanks for you reply - I have finally solved my issue. I was not executing the proper I2C sequence for reading the response. I have rewritten my read() service based on some esp32 examples (my project uses esp32) and it works now,
Best Regards
Thierry
