Connectiong to the iPhone hotspot
pouya
Posted on November 15, 2016 at 08:58
Hi..
I can easily connect the module to any APs and it works fine. But, I can not connect it to the iPhone hotpots.. does hotshots needs additional configuration.?
5 REPLIES 5
Gerardo GALLUCCI
Posted on November 16, 2016 at 18:43
should work at same way...
which security setting are running on your hotspot? What's the output on module?
jerry
pouya
Posted on November 17, 2016 at 14:58
Hi jerry. Thank for reply
As far as iPhone hotspot setting goes, I can only set the password. there are no other parameters in iPhone setting side. in my side, I'm receiving this from the wifi module:
+WIND:0:Console active
+WIND:32:WiFi Hardware Started
+WIND:21:WiFi Scanning
+WIND:35:WiFi Scan Complete (0x0)
+WIND:19:WiFi Join:**:**:**:**:**:**
+WIND:25:WiFi Association with 'Pouya's iPhone' successful
+WIND:40:WiFi Deauthentication:2
Gerardo GALLUCCI
Posted on November 17, 2016 at 16:03
I found an iPhone 6 for testing. This is what I saw on first attempt:
17-Nov-16 15:58:22 [TX] - at+s.wifi=0<CR>
at+s.ssidtxt=iPhone<CR>
at+s.scfg=wifi_wpa_psk_text,12345678<CR>
at+s.scfg=wifi_priv_mode,2<CR>
at+s.scfg=wifi_mode,1<CR>
at+s.scfg=wifi_ht_mode,1<CR>
at+s.scfg=wifi_opr_rate_mask,3FFFCF<CR>
at&w<CR>
at+s.wifi=1<CR>
17-Nov-16 15:58:22 [RX] - at+s.wifi=0<CR><LF>
<CR><LF>
OK<CR><LF>
at+s.ssidtxt=iPhone<CR><LF>
<CR><LF>
OK<CR><LF>
at+s.scfg=wifi_wpa_psk_text,12345678<CR><LF>
<CR><LF>
OK<CR><LF>
at+s.scfg=wifi_priv_mode,2<CR><LF>
<CR><LF>
OK<CR><LF>
at+s.scfg=wifi_mode,1<CR><LF>
<CR><LF>
OK<CR><LF>
at+s.scfg=wifi_ht_mode,1<CR><LF>
<CR><LF>
OK<CR><LF>
at+s.scfg=wifi_opr_rate_mask,3FFFCF<CR><LF>
<CR><LF>
OK<CR><LF>
at&w<CR><LF>
<CR><LF>
OK<CR><LF>
at+s.wifi=1<CR><LF>
<CR><LF>
OK<CR><LF>
<CR><LF>
+WIND:49:WPA:Terminated: 0<CR><LF>
<CR><LF>
+WIND:38:WiFi:Powered Down<CR><LF>
<CR><LF>
+WIND:46:WPA: Crunching PSK...<CR><LF>
<CR><LF>
+WIND:32:WiFi Hardware Started<CR><LF>
<CR><LF>
+WIND:21:WiFi Scanning<CR><LF>
<CR><LF>
+WIND:35:WiFi Scan Complete (0x0)<CR><LF>
<CR><LF>
+WIND:19:WiFi Join:3E:5C:F2:xx:xx:xx<CR><LF>
<CR><LF>
+WIND:25:WiFi Association with 'iPhone' successful<CR><LF>
<CR><LF>
+WIND:51:WPA Handshake Complete<CR><LF>
<CR><LF>
+WIND:24:WiFi Up:172.20.10.2<CR><LF>
BR
j
pouya
Posted on November 18, 2016 at 08:32
Hmmmm........This is interesting,
I'm doing exactly the same thing...
for sure there is something in my code then.
Thanks alot.
pouya
Posted on November 18, 2016 at 14:29
Yap.... it was something small in my code...
Thanks again.
Announcement
