BlueNRG-MS Count of Services? Only 6?
alexandereberhardt9
Posted on June 29, 2016 at 14:46
after adding the 6th service with aci_gatt_add_serv i get the errorcode 0x1f (out of memory) if i add the 7th service?
This error is independent of the count of characteristics in the other services.
How can i increase the possible count of services. I use stack mode 2.
#bluenrg-ms
Posted on June 30, 2016 at 10:44
Dear Customer,
as you can read in the release notes for BlueNRG, BlueNRG-MS Stacks:
''The total number of attributes records for services is 8 (2 are reserved for the default GAP and GATT services) ''
Graziella
