BlueNRG GUI v1.6.0 image download
hui
Posted on April 02, 2015 at 21:58
Hi
I am trying to make GUI work with
TEVAL-IDB002V1 board over USB. Following user manual of DK, the
orange LED DL2 will started to blink. When
I went to Tools->BlueNRG updater..., it said ''Port is closed''.
What does it mean? How can I flash firmware to the board?
thanks!
Hui
#dfu-gui-image-download-steval
Posted on May 11, 2015 at 16:57
Hi Hui,
when the orange LED DL2 will started to blink, the device is put in DFU mode and using this funtionality it's possible to flash another fw of motherboard (Tools->Flash Motherboard Fw..) and no port has to be opened.
Instead, To flash another  fw stack version, you have to:
-  first load the BlueNRG_VCOM.hex  on BlueNRG (putting the device in DFU (device firmware upgrade) mode - orange led 2 blinking)
- after loading of BlueNRG_VCOM.hex, the related COM port has to be opened from GUI, select Tools ->  BlueNRG Updater...select the new stack fw version and update it.
GM
Hi
thanks!
Hui
