2024-12-12 3:46 PM
I am using the VL53l8 sensor. i need to change the ranging frequency. im using the Xcube tof code. I see in the app tof code that #define RANGING_FREQUENCY (10U). so if i change 10u to 15. Willi get ranging frequency to 15 hz.?
Thank u
2024-12-13 9:59 AM
that should work just fine.
and, as you are using an STM32, go ahead and insert:
//Counting cycles is a piece of cake.
//Stick this code somewhere in your code.
cur_timestamp = HAL_GetTick();
printf("%4lums \n",cur_timestamp - prev_timestamp);
prev_timestamp = cur_timestamp;
Each tick is a ms. - but remember that there is going to be a roll-over at some point. But it's great for just testing!!
2024-12-13 9:59 AM
