2024-11-18 12:13 PM - last edited on 2025-09-25 1:21 AM by Anne BIGOT
Hi
we are looking for optical flow sensor and try to configure VD56G3 camera for this purpose which is connected to rasberry pi 4.
I came across research artice which states that it does support optical flow using MIPI CSI-2 interface.
https://arxiv.org/pdf/2305.13087
However just looking at the user manual its not so clear how I can configure camera to output optical flow or displacement of consecutive frames.
Are there any additional materials I can look at or maybe software tools, SDKs that will give any examples of how to do it?
2024-12-16 12:25 AM
Hi ketchyn,
This something we want to enable in 2025 but today the feature is not fully functional in the device.
Cyril
2024-11-20 5:27 AM
Hi Ketchyn,
The optical Flow feature is currently not supported on our sensor we are working to make it available.
2024-11-26 1:50 PM
Thanks @CyrilTechPro for your response
I see in documentation that there is a possibility to add max BRIEF descriptios that are used in feature tracking and is a part of optical flow calculations. Is it something that will be enabled in future?
Are there any suggestions for camera configuration if we write optical flow algorithm on our end?
Olex
2024-12-16 12:25 AM
Hi ketchyn,
Cyril
2025-09-03 2:28 AM
Is there any progress on this topic and when the feature will be available
PanterSoft
