I was wondering if it would be possible to add a lens system to the sensor and focus the emitted light and reduce the field of view.
John E KVAM
I feel this would solve a couple problems. First, it would allow for more energy to be returned to the detector, increasing the signal to noise ratio and second, it would allow customers to focus on more specific areas. My questions are - can this be done?
 (imported question)
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
John E KVAM
PLEASE DO NOT CHANGE THE OPTICS TO CONCENTRATE THE LIGHT.
Everything you said is true, and it would work IN THEORY. But we are dealing with a laser that has been
carefully constructed to be eye-safe. Changing the optics to concentrate the light could make it harmful.
You would need a laser-qualified engineer and be willing to retest your design and submit your findings to the FDA.
940nm light is invisible. It will also penetrate your eye. And you will not know to blink, or turn away.
So keeping the light dispersed so not very much can enter your eye is very important.
So without a fully qualified engineer, please do not change the optics.
John E KVAM
