Why the spinning circle at the bottom of notification feed?
waclawek.jan
It just turns infinitely. Why?
waclawek.jan
Hi @Lina_DABASINSKAITE  ,
> the list expands, and the spinning circle disappears as well
I tried, and at the first attempt, the list expended by exactly one post, the "Show more" disappeared and spinning circle remained... retried, with the same result. Then I decided to retry once more while taking screenshots, but then the behaviour changed, the list expanded by a whole bunch of items, and both "Show more" and spinning circle appeared again. They disappear only upon repeated presses when I get to the very bottom of the list.
Lina_DABASINSKAITE
Community manager
Hello @waclawek.jan ,
I cannot reproduce this issue anymore. On which browser does this happen to you? This could be considered as a performance issue, and we need to check the exact browser.
BR,
Lina
Lina_DABASINSKAITE
Community manager
Legacy message: ‎2023-07-05 03:17 AM
Thanks for brining that up. When you press "Show more", the list expands, and the spinning circle disappears as well. I am looking into it, weather it is an expected UI/UX behavior or a glitch.
Thanks,
Lina
