2022-10-28 5:55 AM
2022-10-28 6:30 AM
If you are generating with Validation or System Performance the syscall.c is actually in X-Cube-AI/app
2022-10-28 6:05 AM
Pressed Ok to early. After setting up a Project in STM32CubeIDE, everything works fine. As soon as adding X-Cube-AI with Network to the project the syscalls.c file is deleted. Since the use of prints etc. for debugging purposes would be nice, I would like to fix this issue. Tried with X-Cube-AI Versions 7.1.0 and 7.2.0. Is anyone facing the same problem or found a solution for it?
2022-10-28 6:30 AM
