2024-07-15 11:05 PM - last edited on 2024-07-17 3:27 AM by Andrew Neil
I am testing DL model on different MCU platform.
Is it possible to get the power consumption information?
And is there any option to change the clock frequency of MCU?
Ritesh
2024-07-17 2:06 AM
You can't change the frequency of the developer cloud platform and we don't have integrated power measurement.
I recommend to create a local project with STM32CubeMX, put the frequency you want and then run the inference on your local board using either validation on target or system performance.
Then to have a estimate of the power consumption, you can use the power consumption calculator integrated in STM32CubeMX, just indicate the run time corresponding to the inference time and you'll have a estimate of the power consumption
2024-07-17 2:06 AM
2024-07-17 3:23 AM - last edited on 2024-07-17 3:27 AM by Andrew Neil
Thank you for providing the solution.
Could you provide any tutorial link for the power estimation using CubeMX software?
RItesh
2024-07-17 3:30 AM
https://www.youtube.com/playlist?list=PLnMKNibPkDnE3c_Ja734geXtlifXE5oaN
#11 - Power Consumption Calculator (PCC):
https://www.youtube.com/watch?v=gxvkgkJjI5A&list=PLnMKNibPkDnE3c_Ja734geXtlifXE5oaN&index=11
2024-07-17 3:35 AM
or in STM32CubeMX just go in help (Help->Help or F1 key) and search for Power Consumption Calculator
