2025-01-08 9:39 PM - last edited on 2025-04-16 9:30 AM by Amel NASRI
I am using X-CUBE-AI to run an AI model on an embedded system. While executing the following line of code:
batch = ai_mnetwork_run(net_exec_ctx[0].handle, ai_input, ai_output);
a Hard Fault error occurs.
What’s puzzling is that the error initially occurred, but without any code modifications or corrective actions, the issue temporarily resolved itself. However, after some time, the same Hard Fault error reappeared.
Has anyone encountered a similar issue, or could you suggest possible solutions?
I would greatly appreciate your help.
Thank you!
