update software ''Read timed out''
‎2014-07-15 7:05 AM
The software update complains (see below log). The proxy is correctly configured. The update list is found but when it downloads the files, the error is coming. My browser can access the jar file so the links are ok... Any suggestion?An error occurred while collecting items to be installed
session context was:(profile=profile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Unable to read repository at http://spc5.drive.cloudforge.com/projects/spc5releases/SPC5Studio_Update_Site/plugins/com.st.tools.spc5.wizard.pinmap.help.en_1.0.0.201407091613.jar.
Read timed out
Unable to read repository at http://spc5.drive.cloudforge.com/projects/spc5releases/SPC5Studio_Update_Site/plugins/com.st.tools.spc5.wizard.pinmap.spc5_1.0.0.201407091613.jar.
Read timed out
Unable to read repository at http://spc5.drive.cloudforge.com/projects/spc5releases/SPC5Studio_Update_Site/plugins/org.chibios.spc5.components.hal_2.6.4.201407091645.jar.
Read timed out
Unable to read repository at http://spc5.drive.cloudforge.com/projects/spc5releases/SPC5Studio_Update_Site/plugins/org.chibios.spc5.components.hal.platform.spc560dxx_1.0.0.201405151619.jar.
Read timed out
Unable to read repository at http://spc5.drive.cloudforge.com/projects/spc5releases/SPC5Studio_Update_Site/plugins/org.chibios.spc5.components.hal.platform.spc564axx_1.0.0.201405151619.jar.
Read timed out
Unable to read repository at http://spc5.drive.cloudforge.com/projects/spc5releases/SPC5Studio_Update_Site/plugins/org.chibios.spc5.components.osal.spc560pxx_1.0.0.201405151619.jar.
Read timed out
Unable to read repository at http://spc5.drive.cloudforge.com/projects/spc5releases/SPC5Studio_Update_Site/plugins/org.chibios.spc5.components.osal.spc563mxx_1.0.0.201405151619.jar.
Read timed out
Unable to read repository at http://spc5.drive.cloudforge.com/projects/spc5releases/SPC5Studio_Update_Site/plugins/org.chibios.spc5.components.spc5hal_1.0.0.201405151619.jar.
Read timed out
Aurélien- Mark as New
‎2014-07-15 8:44 AM
Your problem is linked to your network configuration :if you use a proxy :
1) Set your ''Static'' Proxy in WINDOWS ==> PREFERENCES ==> GENERAL NETWORK CONNECTIONS like your browser ''Dynamic proxy'' is not recommended (example : zscaler) Use Manual Configuration (Cf Screenshot) HTTP and HTTPS only Do not set your SOCKS (let empty)if you do not use a proxy :
Use Direct Configuration You can try your connexion internet by using Show View ==> Other ==> Internal Web browser and try to connect to a web page. Sorry Aurelien , for this you have to ask to your local IT. Is your local IT can permit to access to internet with a tool like Eclipse ? Best regards Erwan YVIN ________________ Attachments : 2014-07-10_095433.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qWJP&d=%2Fa%2F0X0000000boD%2FVmyFwNsl6m9roaar0xGgtGuN5DU7EWS3ehahtKZ76pA&asPdf=false- Mark as New
‎2014-07-16 2:28 AM
Hello Aurelien ,
I have several tries for you :Eclipse environment (from Juno to Luna) is using a cache procedure to connect by update site (p2).1) Could you try to remove the cache directory in your following directory ''\eclipse\p2\org.eclipse.equinox.p2.repository\cache'' ?Restart SPC5Studio and try the update site.2) Are you a local admin in your laptop ?Anyway , to check Internet Connection by ''Internal Web browser'' from SPC5Studio is recommanded to check if your network configuration is correct.Use a dynamic proxy by Proxy autoconfig ((*.pac) and use a web filtering tool is not recommended.If the problem persists, i will contact you directly by mail. Best regards Erwan- Mark as New
‎2014-07-16 7:21 AM
Hello Erwan,
I asked my local IT support, they do use domain filtering but since I can access the file listed in the error log by copy/paste the link in IE, it's another reason. I deleted the cache folder you mentioned but it persists. The error log is now reduced to this file:
session context was:(profile=profile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=). Unable to read repository at . Read timed outPlease find attached my network settings. I do have local admin rights on my machine.
Aurélien ________________ Attachments : Preferences.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0WW&d=%2Fa%2F0X0000000baM%2FGiGUSoxLzLTFtXbZR_cRjcIuKureV6owroOBuhz9JLc&asPdf=false- Mark as New
‎2014-07-17 12:30 AM
Hello Erwan,
I did not changed anything this morning and it worked... Regards, Aurélien- Mark as New
‎2014-07-17 1:31 AM
